Locating the center of radial gradient?
COW Forums : Adobe Illustrator
Dave Cook
on Aug 3, 2015 at 6:39:26 pm
I want to center a graphic over a radial gradient. How can I determine the X/Y coordinates of the center of the gradient and how can I align an object over this--either automatically (an align command?) or manually (duplicating X/Y coordinates?).
Dave
Illustrator CS5, Mac OS X 10.9.5
Kalle Kannisto
Re: Locating the center of radial gradient?
on Aug 19, 2015 at 5:33:04 pm
If you're not trying to get a mathematically perfect alignment, you can select the fill with the gradient tool, which shows the center point, put two guides to show the location then use the bounding bow of the graphic to align it to the guides.
