Error Opening older AI files in AI CS 11.0.0
COW Forums : Adobe Illustrator
Swen Gyrowetz
on Jul 23, 2015 at 5:46:25 pm
When I open older Adobe Illustrator files I get the following message:
"Acrobat PFD File Format is having difficulties. Expected a non-negative integer."
Anyone who knows how to stop it??
My old illustrator file is illustrator 9
Barry Martinson
Re: Error Opening older AI files in AI CS 11.0.0
on Jul 26, 2015 at 11:13:03 am
Try to place the files in a blank AI CS document instead of opening them.
But you have to choose show all documents from the place dialog window in order to be able to select the AI file you want to place.
Also trash the AI CS preferences before attempting this!
If you are still experiencing the issue after applying this fix you can try Illustrator Fix Toolbox
https://www.fixtoolbox.com/illustratorfix.html
