Problem with intersect
COW Forums : Adobe Illustrator
saeb molaee
on Jun 16, 2015 at 7:55:01 am
hi there i want compound these two path in gray circle but it makes problem.
I am amateur please help
AI file is here
http://13x.ir/WNc
Steve Crook Jr
Re: Problem with intersect
on Jun 17, 2015 at 3:35:56 pm
Hi. I'm not sure WHY you want to compound them. If they are just going to stay there visually - leave them grouped and go on.
BUT, I'll be happy to answer your question under the assumption that you need to work with them further. :)
What is causing your problem is that the two V-ish objects are stroked lines, and you need them to be filled paths.
So, select them and Object > Expand and click OK. Now, to make them into a compound path, make sure both are selected and Object > Compound Path > Make *OR* press CTRL-8. You now have a compound path that looks exactly like the two lines did.
Hope it helps.
Steve Crook, Jr.
http://www.stevecrookjr.me
I am a simple creative professional that can get my Adobe suite and a few other creative tools to do what I want. Barely. :)
saeb molaee
on Jun 17, 2015 at 3:44:44 pm
tnx my friend. it works . i need to Adobe AE . I wanted to extrude them in AE.
