Compound path woes
COW Forums : Adobe Illustrator
Moog Gravett
Compound path woes
on Jun 9, 2015 at 10:31:44 am
Hi guys,
Hope you can help with something.
I have a shape. Imagine a circle filled with stripes.
This is created by making a stripe pattern and then using a circle as a clipping mask.
What I want to do now is cut a square out of the stripey inside bit but I can't make a compound object due to the clipping mask.
Any ideas how I can cut a shape out of that?
Moog
Jonathan Ziegler
Re: Compound path woes
on Jun 10, 2015 at 2:19:01 pm
Sounds like you will need to release the clipping mask first, make your changes and then reapply the clipping mask. Please post your progress and any images you can. :)
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
Moog Gravett
on Jun 10, 2015 at 2:24:30 pm
Thanks for the advice!
Somehow I managed to get it working ... i'm still not entirely sure how ;)
Thanks though,
Moog
