Filling gaps between objects
COW Forums : Adobe Illustrator
Steve Sweet
on Jun 8, 2015 at 2:16:55 pm
Excuse me if this is a stupidly simple question but how can I join a number of objects with gaps between them together? Filling the gaps essentially.
I have this from a client
Each segment of the rope is a different object. I want to create a solid version without the gaps between so that I have one solid path I can take into After Effects as a mask.
Thank you.
Vincent Rosati
Re: Filling gaps between objects
on Jun 10, 2015 at 3:32:00 pm
Could you draw a path on top of the rope, then set the weight to achieve the desired thickness.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
