Slimy Text Effect
COW Forums : Adobe Illustrator
Matt Wierbinski
Slimy Text Effect
on May 25, 2015 at 12:10:50 am
Hi everyone! I'm in need of some help. I want to know how to make this effect on some text:
Does anyone know how to make text look like this in Illustrator? If not Illustrator, then Photoshop? Any help would be much appreciated. Thanks!
Vincent Rosati
Re: Slimy Text Effect
on May 25, 2015 at 12:24:49 am
How did the neuron turn out?
https://forums.creativecow.net/thread/245/863721
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Matt Wierbinski
on May 25, 2015 at 12:35:44 am
Hey man, the neuron came out pretty good! I just used the pen tool in Illustrator and ended up making a pattern brush for the spine of the neuron. And then I used the pen tool to make the neuron nucleus..came out pretty damn good!
Vincent Rosati
on May 25, 2015 at 1:32:56 am
Cool.
For this, it looks like maybe Helvetica text with hand drawn art on top.
The highlights and shadows look very much airbrushed.
You can probably handle the shadows with drop shadow, in AI.
The hardest part might be the highlights.
Yes, you could do this all in AI, but do you need to?
I'd do the type and structure (the line art, including the drips, and maybe also the stripes) in AI.
The example below uses; a font, hand drawn drips, offset structures to create the highlights (using Pathfinder > Divide), Inner Glow filter, Drop Shadow filter, and gradients.
To inspect the effects, go into the Appearance palette (with an object selected) and double-click the FX icon.
Note: This is just a quick'n'nasty. You could obviously spend more time on it.
Project file:
8857_driptypetext.zip
Example:
Vince
Matt Wierbinski
on May 25, 2015 at 5:30:51 pm
Wow, thanks for the help! Seriously, this helped me so much!
