illustrator problem " Acrobat PDF Fils Format is having difficulties. The File is damaged and could not be repaired."
COW Forums : Adobe Illustrator
cody lee
on May 7, 2015 at 7:04:25 pm
when i open the ai file, i get this error message.
do you know what to do?
Vincent Rosati
Re: illustrator problem " Acrobat PDF Fils Format is having difficulties. The File is damaged and could not be repaired."
on May 8, 2015 at 12:17:04 am
I suspect the file is just plain corrupted :(
Try opening with Acrobat, and experiment.
Try running it through Distiller.
Try opening with Photoshop.
Here's Adobe's troubleshooting info for this issue: https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-fil...
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
lyons ethan
on May 11, 2015 at 7:14:10 pm
Is it possible that the PDF file format is to new for your version of illustrator to import? Which version of illustrator is it?
For more use Illustrator Repair Toolbox restores corrupted *.AI files in vector graphics editor Adobe Illustrator. Software read corrupted file, analyze data in it and save a recovered data into new .ai file. http://www.repairtoolbox.com/illustratorrepair
