A gradient (from EPS to TIFF) became striped
COW Forums : Adobe Illustrator
John Bright
on Mar 27, 2015 at 7:01:15 pm
Usually i sent all layouts of the stands in EPS and yet with such trouble have not faced - wanted to export from EPS to Tiff, but this led to the striped gradients as a result. I cannot check anti-alias box in the AI export settings, says too big file (probably a computer does not manage). Advise me what to do, as tomorrow i ought to take into print this layout.
Jeronim Winter
Re: A gradient (from EPS to TIFF) became striped
on Apr 2, 2015 at 6:58:24 pm
Save as eps in level 3 and raster it then. This must be done at the very beginning, while exporting to eps.
Disable preview for the eps, theoretically this also might help. Get more free memory (close Illustrator, unload all unnecessary things, load Illustrator) and save the eps.
If nothing works and you are really confused and don’t know what to do – use a third-party then. The good one might help you in the matter. Recovery Toolbox for Illustrator, for example
And the last - Ctrl+A > Ctrl+C > Ctrl+Tab (Photoshop) > Ctrl+N > Ctrl+V > Enter > Ctrl+Shift+S (TIFF). 100dpi should be enough for you if it's a large format printing.
© 2018 All Rights Reserved
