Converting Rounded Corners to Editable Paths
COW Forums : Adobe Illustrator
Eric Jordan
on Feb 22, 2015 at 7:38:09 am
I'm curious if there is an easy way to convert rounded corners (Stylize > Round Corners) to an editable path.
I would like to be able to adjust/edit the rounding points after I've performed the effect on a shape.
Thanks to anyone with some insight.
Cheers, Eric
Steve Crook Jr
Re: Converting Rounded Corners to Editable Paths
on Feb 22, 2015 at 9:41:01 pm
There is indeed an easy way to convert your rounded corners ("Stylize > Round Corners...") to an editable path.
Once you are happy with the effect, go to "Object > Expand Appearance". Done.
If you are using the new rounded corners by dragging the little circle inside the corner of Illustrator CC versions, you go to "Object > Expand..." select all the check boxes and click OK, then ungroup the result and delete the objects you do not want.
Steve Crook, Jr.
http://www.stevecrookjr.me
I am a simple creative professional that can get my Adobe suite and a few other creative tools to do what I want. Barely. :)
