Can I view corrupted ai files in adobe illustrator?
COW Forums : Adobe Illustrator
agneta karlsson
on Jan 6, 2015 at 4:03:21 pm
I save AI-illustrator file and the file was damaged. When you open (I tried different programs) receive the message type "PDF file format is having difficulties. The file is damaged and couldn`t be repaired". Can I view corrupted ai files?
Vincent Rosati
Re: Can I view corrupted ai files in adobe illustrator?
on Jan 6, 2015 at 4:59:50 pm
I'm afraid you might be hosed :(
Try opening the file with: Acrobat, Distiller, and Photoshop to see if anything can be recovered.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Lance Bachmann
on Jan 6, 2015 at 8:50:09 pm
It depends on the percentage of file which gets corrupted. Their is a chance that half of file or 20-30% file data would get recovered.
