illustrator - stroke doesn't connect / brush pattern
COW Forums : Adobe Illustrator
Peter James
on Dec 19, 2014 at 5:12:45 pm
Hello,
so I'm having problems figuring out a stroke issue. Below is an image of what I am referring to.
Essentially, I want to create a brush that I can use on strokes so that no matter the shape, when I use it, I have 3 horizontal lines applied as the stroke.
At the moment, if I use the pattern brush, the outer corners are all over the place. If I use the art brush, the ends do not connect.
What can I do?
