Importing .ai sequence images and exporting to svg
COW Forums : Adobe Illustrator
Andre Watts
on Dec 10, 2014 at 12:36:24 am
I am going to be creating an animated 3d laser show using iShow software. I am currently using Cinema4d in order to create the files needed for the animation. I was told to enable "Sketch and Toon" effect in C4D and export to .ai (choosing all frames and into separate layers).
I did this, but now I am not sure what steps to take in order to import the .ai files into Illustrator. After this, a tutorial I watched stated that you had to export out of Illustrator .svg files. Lastly converting the .svg file to .ilda file, which I am not sure which software does this. iShow recognizes imported .ilda files.
Can someone assist me in giving me direction here? Also, if you have a better process for doing this, that would be great! Thank you in advance. If applicable, I am on a Mac OS using Illustrator CS6.
© 2018 All Rights Reserved
