Export Illustrator Layers to Photoshop that will remain as editable vectors (Smart Objects)?
COW Forums : Adobe Illustrator
Nikola Tomic
on Nov 6, 2014 at 11:15:39 pm
Hi guys
I was trying everything, but none of tutorials helps.
I am trying to export Adobe Illustrator file [a bunch of grouped characters with groups and layers] to PSD and this file to animate in AfterEffects later. What I want is - to all PSD files exported from Illustrator to remain editable in Illustrator [as vectors] or as Smart Objects.
Exporting AI to PSD converts all files to 72/150/300/other DPI which are bitmaps and I don`t want that. The only one way layers stays as vectors is to manually COPY and PASTE layer by layer from AI to PS... which is extremely long work... :( as each layer has to be moved and centered where it should be. I couldn`t find "Paste in Place" as it works in AI...
Maybe there is a script to do so or something?
Thank you very much!
N.
