George Clooney
COW Forums : Adobe Illustrator
Stuart Taylor
George Clooney
on Oct 19, 2014 at 8:37:44 pm
Hi guys came across this image of George Clooney and wondered how the artist rendered this as I would like to render other portraits in a similar style- here's the link http://freeprintablestencils.com/george-clooney-printable-people-stencils.h...
Many thanks in advance Stuart
Darrell Cheeks
Re: George Clooney
on Oct 21, 2014 at 9:02:07 pm
Not sure about Ai, but this is super easy in Photoshop. Open the image and add a threshold adjustment layer. Play with the slider until you get the desired look.
Per Arne Sandvik
Re: George Clooney
on Nov 10, 2014 at 6:50:57 pm
It kind of depends which version of AI you have. In newer versions, you just paste the picture into a document, go to Window > Image Trace, and check "Preview". Then adjust the threshold until you get the effect you want.
If you can't get the result you're after (say, for example, that the nose gets washed out when the eyes look good or the eyes go black when the nose looks right) you'll have to use Photoshop.
The image has to be of a reasonable quality and size, or you just won't get the amount of detail you want.
