Transparency when using grain effect
COW Forums : Adobe Illustrator
Hayley Warren
on Oct 9, 2014 at 12:21:40 pm
I'm experienced with Illustrator but am having an awful lot of trouble trying to achieve this effect. Any ideas would be much appreciated.
I would usually start by creating a shape with a light blue radial gradient, light blue from 100% to 0% opacity. I then go to effect>texture>grain to get the grain that I want, but it is filled with white which I don't want. Usually I would set this to multiply to remove the white, but since this image is lighter than my background, this doesn't work.
Is this possible to achieve in illustrator?
Vincent Rosati
Re: Transparency when using grain effect
on Oct 9, 2014 at 3:28:50 pm
I might try just creating the texture in Photoshop, then placing the the texture in the AI file, and using your shape as a clipping mask.
Maybe, you'll have 2 layers - the gradient underneath, and the texture set to multiply on top.
Put the Ai file and source texture in its own project folder.
in PS, maybe...
On a black layer, Filter Noise, then scale to 400%, then maybe Gaussian blur.
Or
On a black layer, Filter Reticulation, then scale to 200%, then maybe Unsharp mask.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Hayley Warren
on Oct 9, 2014 at 4:06:32 pm
Yes, using PS seems like it will be a lot less hassle. Thanks Vincent!
