16 Bit color
COW Forums : Adobe Illustrator
Fran Zine
16 Bit color
on Jul 16, 2014 at 10:04:00 am
Hello guys,
i think its a rarely asked question.
i should do some icons... but i have to do it with 16 bit colors... The device on which they are to be used, only allows 16 Bit... otherwise it leads to incorrect display.
But i cannot find that option in illustrator while creating a new file?
Does anybody know something??
Vincent Rosati
Re: 16 Bit color
on Jul 16, 2014 at 3:38:25 pm
By restricting the color palette to 16 bit means, I think, that you simply don't get a full palette grayscale alpha channel. 16 bit and 24 bit color have the same number of colors, except that in 24 bit you get a grayscale alpha channel (the extra 8 bits), as opposed to the 1 bit alpha channel of the 16 bit specification.
So, you can still use transparency, but it has to be 1 bit, hard-edge transparency as in a GIF, not soft-edge transparency like a PNG-24 (24-bit, 16 bit + 8 bit alpha channel.)
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
