What is happening here and how can I fix it?
COW Forums : Adobe Illustrator
Tim Boknecht
on Jul 11, 2014 at 4:59:21 pm
I've created a logo with a custom "C" character and turned the entire logo into a single compound path.
It looks like this:
Trouble is, when I apply a graphic style to the compound path, the C gets all goofy on me.
It looks like this:
It doesn't seem to matter what graphic style I apply. I've tried several and get the same result each time. I've isolated the C and made sure there were no stray points. I've run a simplify on it. Still get this goofy result.
Can anyone explain to me what's going on here and how I can fix it?
Here's what the path looks like:
Tim Boknecht
Media Producer
Bravo Productions
Vincent Rosati
Re: What is happening here and how can I fix it?
on Jul 11, 2014 at 8:59:08 pm
Hey Tim - I'm almost certain that the path in the C is cut, or is otherwise multiple paths.
Maybe try resetting the path and fill of the compound object, than try Pathfinder / Unite. This could clean the C. Than retry the graphic style.
If that doesn't work, test all of the problem points in the C with the Direct Select to. You'd be looking for broken paths, by moving the points. If you do find a broken path you would use the Join command.
Worst case scenario, upload the file and someone will fix it.
Just some initial thoughts.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
