How do I Recreate a Logo in Illustrator
COW Forums : Adobe Illustrator
Roger Coles
on Apr 15, 2014 at 1:14:45 pm
I am trying to recreate this logo in Illustrator but can't figure out how to do it. Not sure how to do the dots. Can someone please help?
Jonathan Ziegler
Re: How do I Recreate a Logo in Illustrator
on Apr 16, 2014 at 4:11:04 pm
The easy way is to create a single line of dots with one dot at the center. Group the line, then select the rotate tool and reset the center point to be the "center dot" created above. Option-rotate to duplicate the row of dots using the center dot as a fulcrum, then use repeat to make as many as you like. When done, ungroup a couple times and delete the center dots. Done. :)
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
