How to make entire path object warp as it appears after Effect Warp Arc.
COW Forums : Adobe Illustrator
Lars Ervik
on Apr 10, 2014 at 7:34:52 pm
Hi.
I have a path object that I want to export to Roland Cutstudio for cutting vinyl decals.
I need to have the object arced to get the shape I need. So I used the Effect, Warp, Arc to get the shape I need.
But the problem is that the paths stay unchanged as a straight baseline. Only the Appearance on the screen change. So when I use the Roland Cutstudio plug-in, the paths are exported without the arc-effect. You can see in the lower left hand corner on the screenshot, how the Roland Plugin sees the object, without the arc effect)
So my question is, How can I arc the path object in Illustrator so that also the PATHS arc in the same way as it the Appearance on the screen?
Vincent Rosati
Re: How to make entire path object warp as it appears after Effect Warp Arc.
on Apr 10, 2014 at 8:51:48 pm
Try - Object / Expand
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Lars Ervik
on Apr 11, 2014 at 2:32:23 pm
Perfect!! That wasexactly the solution I was searching for! Thanks a million /Regards, Lars
