Getting Paths to Top Layer For Export to After Effects
COW Forums : Adobe Illustrator
Devin Jameson
on Mar 27, 2014 at 3:15:24 pm
Just can't figure this out. I have all these paths and I want to get them to the top layer. I've tried to expand to them to make them objects and then pull them up to the top layer, but expanding won't work for some reason. Help?
Vincent Rosati
Re: Getting Paths to Top Layer For Export to After Effects
on Mar 27, 2014 at 8:55:50 pm
Not sure what you're ultimate goal is, but you could...
1) Select everything and Object / Group.
That will move all of the objects into one layer.
Or, you could just drag the paths inside the Layers palette to the appropriate layer.
or maybe...
2) Select all of the like-filled objects and Object / Compound Path / Make.
This way, all of the dark greens will be one object, and the light greens will be a second object.
You would still need to group the dark green and light green, if you want them to be together.
Just some initial thoughts.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
