hot text
COW Forums : Adobe Illustrator
sean wilms
hot text
on Mar 25, 2014 at 12:55:28 am
HI I was wondering if this can be done in illustrator wanted the text to be curve like in this pic
Vincent Rosati
Re: hot text
on Mar 27, 2014 at 9:15:54 pm
It looks like the issue might be in achieving the warping of the text glyphs.
I'm guessing that you've tried Text on Path.
Try expanding your text, than either...
Object / Envelope Distort / Warp: Arc
or manually with...
Object / Envelope Distort / Warp: Mesh (1 row, 2 columns)
The two words would be created in 2 operations, one for the upper and one for the lower.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
sean wilms
Re: hot text
on Apr 1, 2014 at 2:10:37 pm
yes I tried textmon a path I will give your suggestion a try
thank you!
sean wilms
Re: hot text
on Apr 1, 2014 at 3:01:43 pm
Thank you Vincent your advise worked perfectly the expand type did the trick, I was using envolope-make with upper to get the effect but it doesn't work with compound objects.
thanks a lot for your help
