Multicolor Gaussian Blur
COW Forums : Adobe Illustrator
Jimmy Afterglow
on Mar 14, 2014 at 6:35:32 pm
Hey all,
Pretty new to illlustrator and would like to create something like this image below with more colours, any instructions?
http://wallpaperology.com/17-Abstract-wallpapers/54-3D---Abstract-wallpaper...
Many thanks
Vincent Rosati
Re: Multicolor Gaussian Blur
on Mar 14, 2014 at 8:53:07 pm
You're much more likely to get a response if you use a real name. I'm not sure if this is still in the TOS, but the COW policy has been that real names are required, no handles or spam-type names. They changed this maybe about 4 years ago.
I used to be 'Vintendo'.
Jimmy Afterglow
on Mar 14, 2014 at 9:56:49 pm
My real name is Jimmy Afterglow... problem?
Vincent Rosati
on Mar 15, 2014 at 2:05:01 am
The attached files illustrate two approaches to this:
1 - Gradient Mesh
2 - Blend
Blend options (CS4)
7235_gauscs4.ai.zip
Blend options (v.10)
7236_gausv10.ai.zip
You'll see two versions of the Blend approach. The lower resolution/stepped version is simply to show how you might reduce your CPU processing needs while testing. It is the same artwork, but with a lower step value in the blend.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Jonathan Ziegler
on Mar 18, 2014 at 4:48:11 pm
In Illustrator or Photoshop, it should be pretty basic. I would think it would take a few seconds in photoshop or illustrator. Just create the image, lay down your colors and add a Gaussian blur. Have you tried this?
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
