Problems when I create a table. I cant align the text and the table cell
COW Forums : Adobe Illustrator
Darragh Griffin
on Feb 27, 2014 at 8:27:21 am
Hi
When I create a table by going to Object > path > split into grid....so far so good. But when I want to type something into the table cells with the text tool... the stroke of the cell disappears.
This leads to another problem because when I go to align tool, to center the text with the table cell, I cant seem to select both the cell and the text to align them. Of course the cell not having a stroke doesn't make it easier!
THanks
Vincent Rosati
Re: Problems when I create a table. I cant align the text and the table cell
on Feb 27, 2014 at 9:11:30 pm
I suspect that when you enter the text your turning the squares into text objects.
Would it be possible to select the grid and Copy/Paste in Front. Lock the lower stroked grid, and type on the upper grid?
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
