Illustrator function: random scatter pattern
COW Forums : Adobe Illustrator
Dan Rather
on Feb 6, 2014 at 2:42:13 am
Hello all.
I'm making a package label, and want a background pattern. The easiest way to describe it is to imagine dandelion seeds blowing in the wind. I want to draw one seed and hope illustrator can make a random scatter with adjustable size and orientation of the object and density of its scattering.
Can anyone tell me if this feature exists, and what it's called so I can research further?
TIA!
Vincent Rosati
Re: Illustrator function: random scatter pattern
on Feb 6, 2014 at 2:51:18 am
Try dragging your object into the Brushes pallette, and create a Scatter Brush.
The scatter brush has all of controls you describe.
Than you just draw a path and apply the your custom bush.
You can go back into the brush editor of you need to make additional changes.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Dan Rather
on Feb 6, 2014 at 3:29:31 am
Thank you!
