important question about a design
COW Forums : Adobe Illustrator
chaim machlev
on Jan 30, 2014 at 12:36:52 am
sorry to disturb you guys but i am trying for weeks to find a way to create a design like this one,
does anyone has a clue which tools i should use ?
Thanks a lot
I really appreciate it !
Vincent Rosati
Re: important question about a design
on Jan 30, 2014 at 9:29:46 pm
Oh brother! You're getting into more advanced type illustration, given this example.
Here are the steps outlined in the attached AI file.
I'm sure there are a dozen ways you could do this, but hopefully this will give you some ideas.
1 - Create an object with the Polygon tool.
2 - Make it fancy.
Object Blend Specified Steps.
Add Effect Distort Zig Zag.
Expand.
Pathfinder Minus Back.
Cleanup.
3 - Duplicate with Cmd + D to create the pattern.
See: http://library.creativecow.net/articles/rosati_vincent/radial_patterns.php
4 - Object Envelope Distort Make with Top Object.
Working example file here:
7074_warpedpatternv10.ai.zip
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
