resize symbol icons
COW Forums : Adobe Illustrator
Mike Brown
resize symbol icons
on Jan 4, 2014 at 2:06:03 am
Hello,
When I'm working on a laptop, even with 'large list view' selected I cannot see the symbol icons. Without using them first I cannot tell what they are.
Is there a way to make them bigger than the options available?
Vincent Rosati
Re: resize symbol icons
on Jan 6, 2014 at 2:03:40 am
Nothing more that Large List, I'm afraid. Have you found any other solutions?
Is the issue that they are just too small, or that they are not there?
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Mike Brown
on Jan 6, 2014 at 2:09:17 am
They're there. They're just tiny. Even large view. I probably won't use them very often but unfortunately the only way to see if there is anything useful I will have to drag every one of them out and then re size them. That's an awful lot of time just to see if I may ever want to use one.
Anyway, thanks for the reply.
Vincent Rosati
on Jan 6, 2014 at 2:22:47 am
Post a screenshot, if you get a chance.
Vince
Mike Brown
on Jan 6, 2014 at 2:44:37 am
I'll live with it. It would just be nice to enlarge them enough to see clearly.
