Combining many paths into one path so After effects reads it as 1 mask
COW Forums : Adobe Illustrator
James Pierson
on Dec 11, 2013 at 3:15:08 pm
Hello,
I have an image I have drawn in Flash/Illustrator with the pen tool (so all the lines are paths, no fills).
From Illustrator I want to copy the path, and paste it into After effects as a mask, with the goal to apply the stroke effect, and also have an image follow the same path at the same time.
However, when I bring it into after effects there are 30+ masks, as the paths I am copying from Illustrator interpret as lots of individual paths, rather then one whole mask/path.
I tired the 'join' command in Illustrator, but that creates lots of ugly straight lines all over my image. I also tried using unite command with 'pathfinder' but to the same result (lots of lines all over the place). Making a compound path does also not work, as After effects still sees the paths as lots of individual paths..
Any help would be greatly appreciated.
Many thanks!
Vincent Rosati
Re: Combining many paths into one path so After effects reads it as 1 mask
on Jan 6, 2014 at 1:42:23 am
I think you almost had it with Pathfinder / Unite. You'd just need to Object / Expand before copying out of Illustrator.
Some versions of AI also have a command option, when you click the Unite button, that will automatically expand it. Don't remember which though.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
