Removing Overlapping Points without Affecting Overall Image
COW Forums : Adobe Illustrator
Brandon Wilson
on Nov 22, 2013 at 7:16:32 am
I'm very new to Illustrator CS6, so this is probably a rookie question-
I need these invisible points out of that main path (see the first image with two superimposed red circles) so that no needless overlapping occurs, but whenever I selectively delete them it also deletes fragments of the paths I need to keep.
In a perfect world, I'd have what's depicted in the second image (photoshopped). I've got hundreds of these points to get rid of all in that one main path.
Brandon Wilson
Re: Removing Overlapping Points without Affecting Overall Image
on Nov 23, 2013 at 1:43:07 am
Got it.
Selected the intersecting paths, then under the pathfinder window I used the Shape Mode Unite.
