adobe illustrator tracing a text with vector pen..
COW Forums : Adobe Illustrator
tom wielgat
on Nov 18, 2013 at 3:45:24 pm
In adobe illustrator cs4 i traced a text image with a vector pen tool as seen in the link below
http://www.battaliausa.com/sample2.png
When i render it in max the text is not all filled in, in the middle
as seen in the link below, the b is fine but the rest is not,,
http://www.battaliausa.com/sample1.png
The B and the line are fine but the rest need to be grouped or something
How to i merge the rest of the text togather
The out side of the a with the inside part,,
http://www.battaliausa.com/sample3.png
as you can see in this link the letter b and the line i traced is fine
the rest is not..
Hope someone can under stand this..
thanks for any help
Katya Austin
Re: adobe illustrator tracing a text with vector pen..
on Nov 18, 2013 at 4:08:17 pm
Try selecting all 3 inner parts for A letters and convert them into a Compound path - Object Menu on top > Compound Path > Make (Ctrl+8).
Then select text outline for "ATTALIA" letters and compounded path for all 3 'holes' and hit 'exclude' button in a Pathfinder menu:
Set fill to whatever you want and apply 3D extrude filter
