Select a column from a tab delimited
COW Forums : Adobe Illustrator
thiery roussel
on Nov 14, 2013 at 1:28:55 am
Q?
Is it possible to select only one column of text separate by tab
I'm in the process of creating a template for closing ending.... trilling!
And I figure the tabs will be the simplest way to get the standard 2 column.
But I want to be able to select only the left or right column and apply a different character style.
How do i get this?
My dummy text is formatted like this;
(tab) Title (tab) Full Name
(tab) Driver (tab) John Doe
Best
Jonathan Ziegler
Re: Select a column from a tab delimited
on Nov 14, 2013 at 1:35:55 pm
Honestly, I think you're better off using something like Indesign to do this. It has many detailed text tools that will really make the job easy. You can always import a PDF version back into Illustrator later on.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
thiery roussel
on Nov 14, 2013 at 2:00:43 pm
thanks
I'll look for something like this into Indesign.
