combine colors from an object into another
COW Forums : Adobe Illustrator
Gabriel Ristea
on Nov 12, 2013 at 9:35:17 am
Hi guys and first of all sorry for my bad english.
I am a beginner in illustrator and what I need tot do is:
I have one object (with multiple color) and another object that I want to put colors from the firs
This is the object that i want to color
with this object
can you tell me how to do this? :(
Jonathan Ziegler
Re: combine colors from an object into another
on Nov 13, 2013 at 2:18:43 pm
Sounds like you are doing a clipping mask. Arrange your 2 objects (assuming both are vector objects) by positioning first the colored part how you want it, then put the paint daub above it. Select both objects, then go to Object >> Clipping Mask >> Make or Command-7 or CTRL-7.
If they are not both vector objects, use Photoshop to combine them.
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
Gabriel Ristea
on Nov 13, 2013 at 2:21:57 pm
Thank you i will try. Pattern will be ok?
Jonathan Ziegler
on Nov 13, 2013 at 3:27:25 pm
Well, try it and you can always UNDO.
Jonathan Ziegler
520-360-8293
