How can I make this background?
COW Forums : Adobe Illustrator
Jesper Juel
on Sep 14, 2013 at 9:23:41 am
Hi everyone and thanks for your help.
I need a vector bashouckground like this one here: http://imgur.com/S22mZOE
But I am a little lost of how I should do this. Please can anyone give me some tips, or hints on how I should be doing this.
Thanks.
Jesper
Learning illustrator
Phil Lee
Re: How can I make this background?
on Sep 17, 2013 at 4:55:12 pm
I'm sure there will be a more professional approach however I'm a bit of a newbie myself.
You can create s crude version by using the Live trace tool!
  • Open a new file choosing the correct settings based on the media you intend this artwork to be used on.
  • Place the image onto your new artboard.
  • Click on the drop down options next to the Image Trace button and select high fidelity.
  • Then from the Image Trace advanced options change the Path and Corners to 100%
This is a png of what was created : http://imgur.com/Ddzy2NM
Phil Lee
on Sep 18, 2013 at 9:31:14 am
I found this on my travels which should help you be able to achieve what you are after:
