Very basic problem with brush tool and colour
COW Forums : Adobe Illustrator
Win Edson
on Sep 4, 2013 at 9:12:36 pm
Sorry if this seems utterly basic, but I've googled this for the last 2 days and still can't find a solution.
When I select a colour and stroke size, then attempt to use the paintbrush tool (or pencil tool)- it defaults back to no colour and a thin black stroke.
This does not happen when I use the pen or rectangle tools.
I'm using CS 5.5.
Any help much appreciated!
Win
Jonathan Ziegler
Re: Very basic problem with brush tool and colour
on Sep 5, 2013 at 3:36:39 pm
Hey there, first off, what type of brush do you have selected? Also, if you have settings for a tablet or stylus and you're using a mouse (for example, if the brush size is dependent on pressure), it can cause issues. Double-check your brush presets - you may have set something and not realized it. Barring that, you can always reset prefs (I think its CMD-OPT-SHIFT on startup or CTRL-ALT-SHIFT) or trash the prefs.
Let us know. :)
Save early. Save often.
Jonathan Ziegler
http://www.electrictiger.com
520-360-8293
Aaron Mellman
on Apr 3, 2016 at 9:39:22 pm
I'm having the exact same problem. I've reset all of my preferences and have even reinstalled Ai. Any help would be greatly appreciated.
