Creating an animation in Illustrator
COW Forums : Adobe Illustrator
Maria Reverbei
on Apr 27, 2013 at 5:19:13 am
I animate mostly using Flash. It's been a while since I've created an animated sequence in illustrator and would like to try it again. Does anyone know how to do this? Thanks everyone :-)
Vincent Rosati
Re: Creating an animation in Illustrator
on Aug 7, 2013 at 11:59:54 pm
I don't think I've ever animated with Illustrator, per se.
I might create multiple artboards if I needed to do cells.
Otherwise, I might have one master file with all of the elements.
...just some general thoughts.
Did you make any progress with this?
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Maria Reverbei
on Aug 13, 2013 at 1:26:59 am
Thanks Vince.
I actually put it aside due to work load. I do remember creating the animation by using different layers for each movement, then using automation (years ago!). When I get some time, I'm gonna give it try.
Maria
