How to cookie cut object
COW Forums : Adobe Illustrator
Ivan Minic
on Apr 10, 2013 at 12:03:08 pm
i object 1( made only of strokes(open paths), cut with object 2 so i can get object 3 but only made of strokes(open paths) not expanded, but nothing work, divide objects bellow, pathfinder... i dont know what i'm doind wrong
illustrator cs6
is it possible that illustrator cant cut open paths?
please help
thx inadvance
Tylor Larson
Re: How to cookie cut object
on Apr 10, 2013 at 3:22:47 pm
i dont have cs6 but i did this in cs5.5.. unless something changed between the versions.
so i made some Lines.... AKA open paths... i then made a circle. just like you did
i then selected everything
in the path finder i use the outline button... i then applied a new stroke color and used the hollow arrow to delete all the extra stuff i didn't need. i also switched over to outline mode to make sure i deleted all the extra elements. this should leave you with a set of lines outside the circle that are still open paths.
Ty
Ivan Minic
on Apr 10, 2013 at 3:46:36 pm
thx, i knew that but i thought that there is a way to do it witdouth having to manualy delete unwanted parts
tnx again
Tylor Larson
on Apr 11, 2013 at 4:54:40 pm
if you use the lasso tool on the paths you want to keep and then go to selection/ invert and hit delete twice you should have what you want.
