adding shadows to a character
COW Forums : Adobe Illustrator
keith vickers
on Jan 30, 2013 at 10:12:03 pm
I have created this character.
Right now I am creating shapes, drawing my "shadows" over the top of the character and using the path order in the layer palete in order to hide things. I am having trouble getting some shadows to fit snugly to the outline of my character.
To any wise forum member:
Is there a way to create these types of shading quickly?
Many thanks in advance
Peace.
Vincent Rosati
Re: adding shadows to a character
on Jan 31, 2013 at 2:39:36 am
My initial thought would be to put all of your structure, the black ink, in a new layer on top. Then do all of your coloring in the lower layer - maybe even create multiple 'color' layers, like; base, shadows, highlights, etc.
Just some initial thoughts.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Per Arne Sandvik
on Apr 25, 2013 at 4:02:22 pm
This thread is pretty old, but if you're still keeping an eye on it, you should check out the "draw inside" function.
