Dotcomb needed
COW Forums : Adobe Illustrator
andi doede
Dotcomb needed
on Jan 28, 2013 at 2:00:52 pm
Hello!
I look for the solution of a problem in creating a dynamic graphic. First, I do not know if this is possible at all with Illustrator, but perhaps someone has a solution for me.
I would like to create a honeycomb pattern, which should act as a model for filling. Here I would like to implement a Dynamic scaling of the objects to the right or left side. I have try with the perspective grid sampled, but in this course, the proportions shifted, what should not have been intended. My plan is difficult to describe, so is a screenshot to illustrate:
Maybe there is the possibility of automation based on a single circle. That would be optimal. Scryptographer I've ever seen me, but with my modest mathematical skills, I do not look through it.
Thank you apologize in advance!
Sorry for bad english. I have used the Google-translate
