AI window not refreshing properly
COW Forums : Adobe Illustrator
Leoini Mohan
on Jan 20, 2013 at 1:07:12 pm
I am trying to use 64bit version of AI CS6. However, the window start to freeze when i try to move objects! Have a look at the attached video to get a clear idea. Please help.
http://reels.creativecow.net/film/ai-window-freeze
This is not happening with the 32bit version!
Vincent Rosati
Re: AI window not refreshing properly
on Jan 25, 2013 at 2:47:35 am
Maybe, fill out your profile with your specs; model, os, ram, video card, etc. As much as you can add.
Is Illustrator a new install? New computer? Any recent mods? Have you restarted the system since the issue began?
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
