CS2 ignores line thickness of svg, pdf, ps, eps
COW Forums : Adobe Illustrator
Helmut Haase
on Jan 18, 2013 at 9:31:55 am
Hallo,
when I open a pdf with lines of different thicknesses in my VISTA AI CS2 they are all shown with the same thickness under Prieview. The origin of the pdf is vectorial export from Scilab. In Scilab the lines are o.k. of course.
The strange thing is: It used to function properly before. What can I do to find back to different line thicknesses?
Kind regards
Helmut
Tylor Larson
Re: CS2 ignores line thickness of svg, pdf, ps, eps
on Jan 18, 2013 at 4:59:00 pm
what operation system are you on?
Helmut Haase
on Jan 18, 2013 at 5:22:27 pm
Hallo Tylor,
Thanks for your quick response! The OS is VISTA Home Premium, SP2, CR 2007.
I just checked if the lines are good when produced by Scilab 5.3. They are! I work with Version 5.4 now. It looks like I should ask a Scilab forum.
Nevertheless don't hesitate to analye my problem if there is something to add.
Kind regards
Helmut
