Swirls
COW Forums : Adobe Illustrator
Frizl Sizl
Swirls
on Dec 19, 2012 at 8:26:09 am
Hello,
Does anybody know how to make these kind of swirls?
Tylor Larson
Re: Swirls
on Dec 19, 2012 at 6:06:11 pm
you should use the blend shape tool. create a path, that is one end of the ribbon. Then create a second path that is the other end of the ribbon and then use the blend shape between the two paths.
http://vector.tutsplus.com/tutorials/tools-tips/illustrators-blend-tool-a-c...
this is a great tut on how the tool works. if this response helps please check it as a solution.
Ty
Frizl Sizl
Re: Swirls
on Dec 20, 2012 at 6:51:23 am
Thanks a bunch, very helpfull!
Frizl
