achieving specific texture
COW Forums : Adobe Illustrator
John Kim
on Dec 17, 2012 at 5:04:42 pm
Hi, I am having trouble achieving a certain type of texture. I have tried using the grain filter in the options, but just doesn't have the same feel. Help would be much appreciated.
Here is a sample of the type of texture I am trying to achieve.
Vincent Rosati
Re: achieving specific texture
on Dec 28, 2012 at 2:59:15 am
Would you simply be able to File / Place the tile raster image into your Illustrator file, than drag the tile into your Swatches palate to use it as a fill?
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
