Easy way to recreate this wavy shape?
COW Forums : Adobe Illustrator
Leon Ragetlie
on Oct 27, 2012 at 11:43:51 am
Is there an easy and accurate way to recreate this shape in illustrator? I've been trying with the pen tool but can't get it perfect.
Vincent Rosati
Re: Easy way to recreate this wavy shape?
on Oct 27, 2012 at 4:36:52 pm
I'd bet a number of your fonts have that shape for a tilde, but drawing with the pen tool probably is the best way.
That shape should have 4 points, one on each end and one on each of the sides at the middle. After you use the pen tool you would probably also use the direct select tool and the possible the convert anchor point tool to refine the curves.
Maybe watch this tutorial video:
http://library.creativecow.net/articles/rosati_vincent/ai_helix_2/video-tut...
It shows some techniques for refining paths.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
