Gradient on stroke showing weird results
COW Forums : Adobe Illustrator
Otto Lindqvist
on Sep 26, 2012 at 6:13:55 am
Hello,
First time I'm posting on Illustrator section..
To the problem. I crashed into a problem when using gradient on a stroke. I have this curved path where is a stroke coloured with gradient going on the path. All the curves are on same angle (created with guides) but the middle curve have these weird bumps on it. I wasnt able to find out why that is happening. Have you ever seen anything like that? And how to solve it?
If it's not moving, animate it
Vincent Rosati
Re: Gradient on stroke showing weird results
on Oct 8, 2012 at 11:47:51 pm
Not exactly sure what's happening here, but I'd try using the Convert Anchor Point Tool on that point - under the pen tools.
Click-and-Drag the point.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
