Creating a pattern/shape in illustrator
COW Forums : Adobe Illustrator
Thomas Frank
on Sep 20, 2012 at 12:11:44 pm
What is a good and easy way to create a pattern shape like this one?
I would need all the rounded (Circle) edges the be same shape.
Vincent Rosati
Re: Creating a pattern/shape in illustrator
on Sep 23, 2012 at 4:14:27 pm
http://library.creativecow.net/articles/rosati_vincent/radial_patterns/vide...
Use the radial pattern technique, than put a large circle in the middle to mask the central area.
Finally, you could select all and Pathfinder > Unite.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
