un-unlockable illustrator objects?
COW Forums : Adobe Illustrator
Wade Stubanas
on Sep 17, 2012 at 7:21:43 pm
I am working on a periodic table (received from a client).
I have unlocked everything on the document, however the element boxes are still locked and unmovable, editable, etc.
I can select the Li, Be, 004, and element names, but not the boxes. What is going on here?
Vincent Rosati
Re: un-unlockable illustrator objects?
on Sep 18, 2012 at 12:41:21 am
Verify that everything is unlocked..
mac opt + cmd + 2
pc ctrl + alt + 2 (i think)
Any chance you can attach the file?
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Wade Stubanas
on Sep 18, 2012 at 1:01:10 am
Vincent,
Here is the file.
4672_periodictablebrochure9172012.ai.zip
not sure hot to PM you the PW, so whatever, its 4809.
Thanks for taking a look!
David Cabestany
on Sep 18, 2012 at 12:07:58 pm
They are in a separate locked layer.
Go to the layers panel and click the lock icon.
Wade Stubanas
on Sep 18, 2012 at 3:35:02 pm
That is it! Thank you!
