Round off pixel positions to whole numbers? Align or conform points?
COW Forums : Adobe Illustrator
Daniel Sleeth
on Sep 12, 2012 at 9:12:03 am
I have three layers, each being a bunch of lines that outline the walls of the three floors of this building. The lines do not match up with the other levels due to them having been traced at different scales from a print out.
Is there a way to automatically snap the points of all my lines to the nearest whole pixel? For example, if one of the points of a line is at x=34.345, can I make it snap to x=34 so that the points and lines match up perfectly to the points and lines of the same wall on the other layers?
I have ticked 'Align to Pixel Grid' and set the document to pixels but I am hoping there is an option to round up the positon values!
Many thanks
David Cabestany
Re: ound off pixel positions to whole numbers? Align or conform points?
on Sep 18, 2012 at 12:19:09 pm
I'm not sure if i understood what you're trying to do, but you can select the points (not the entire objects) that you need to align and use the align panel.
