exporting ai file to TIFF in correct seize
COW Forums : Adobe Illustrator
Alexandre Brandt
on Aug 29, 2012 at 9:04:55 pm
Hello all,
I've got an Ai file that is done on the DV PAL widescreen profile (1050 px by 576 px).
I'm making a simple background for DVD menu done Apple DVD studio pro.
Anyways, I'm trying to export this Ai file to TIFF but the output has a different resolution. Indeed, the export is 1067 × 730. I tried different formats like JPEG etc. its the same.
My output settings are 72 ppi same as the profile settings when I made the Ai project.
I'm wondering if there is something I'm missing or doing wrong in the workflow line.
Thanks for your attention !
motion pictures + storytelling = ?
-> FILMMAKING !
Vincent Rosati
Re: exporting ai file to TIFF in correct seize
on Aug 29, 2012 at 11:29:32 pm
You might have objects or effects outside the frame that are increasing the size. Maybe try applying clipping masks - if exporting from AI.
Or you could just import the AI with Photoshop and set the Page Options to Media Box and the size should be correct.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Alexandre Brandt
on Aug 30, 2012 at 9:48:39 pm
Great. The importing to Photoshop worked perfect. Thx.
-> FILMMAKING !
