Cutting an object to seperate layers
COW Forums : Adobe Illustrator
keith vickers
on Aug 15, 2012 at 11:28:03 am
Hi guys, I am trying to cut a vector graphic into many small fragments and then spread each fragment so it has its own layer. This I will import into After Effects cs5.5 to animate the seperate pices .
example:
http://vimeo.com/channels/39226
Here greymachine uses type. I have a vector shape.when I try to use the knife tool I end up cutting great channels from my shape. I want to cut the vector shape up with no trace of the knife tool when I bring the layers into after effects.
Can any wise member here point me in the right direction?
Peace
keith vickers
Re: Cutting an object to seperate layers
on Aug 15, 2012 at 3:53:51 pm
Problem solved. Illustrator had crashed leaving me with the eraser tool even though the knife tool was selected and showing as the active tool. Even when I restarted Ilustrator the problem kept happening.
In the end I rebooted my PC-windows 7 and now I am happily cutting my vector shape with the knife tool.
peace
Tylor Larson
on Aug 28, 2012 at 1:44:31 pm
i was just about to say that the knife tool wouldn't do that... but the eraser tool would... and then i checked the rest of the thread... funny. have fun.
