Illustrator CS5 (Win7) – Problems when grouping elements and using Isolation mode
COW Forums : Adobe Illustrator
Bertil Oldenburg
on Aug 9, 2012 at 8:45:42 pm
Is there a difference in how grouping elements and using isolation mode works in Illustrator CS5 in Mac and Windows?
I’ve tried it in Windows and the isolation mode only partly works - some element doesn’t group together and other objects (the ones not selected) doesn’t fade when I try to build larger groups (with more than two child groups in one parent group).
I’ll post more details when/if needed.
All help is appreciated.
Kind Regards
Bertil
Bertil Oldenburg
Re: Illustrator CS5 (Win7) – Problems when grouping elements and using Isolation mode
on Aug 12, 2012 at 11:18:51 pm
Solved it myself.
The solution:
Use the layer pane instead of the selection tool.
Kind Regards
Bertil
