Image to Solid
COW Forums : Adobe Illustrator
Matt Gillman
Image to Solid
on Aug 6, 2012 at 5:51:26 pm
Right, I have a problem. I have this is image (JPEG), first I opened it in PhotoShop and used colour range to select the parts I wanted, copied them to a new PSD, saved it, opened the PSD through illustrator and I am now trying to convert that image contents into a solid.
The attached image shows what i'm dealing with. Is there a quick way to get all those collated circles selected and changed to individual solids?
Vincent Rosati
Re: Image to Solid
on Aug 21, 2012 at 12:23:59 am
Sounds like you probably want to do a live trace.
Select the raster object, then click the Live Trace button up under the main menu.
Here's a thread that goes into some detail about live trace...
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
© 2018 All Rights Reserved
